The motor was not properly stored and it's been 1 1/2 years since it has run. I've drained and replaced the gas, etc and replaced the spark plugs. Prior to that is was well maintained and taken for regular service.
The elec. starter "works" (turns the starter motor for a few revelotions) but does not start the motor. Both the pull cord/emergency pull give the same result - once or twice I've gotten a cough/sputter -- but nothing that catches the pistons.
It seems to me I am not getting any spark. I tried the starter with a new spark plug plugged into the connector but not into the motor and I can not see any type of spark (day light, so it may be difficult to see). Not sure I grounded it properly - plan to test that next visit to the marina.
The kill switch key is in place, but I have not tried to bypass/disable for testing - not sure how to but will fiddle with it.
The old plugs appear to be ok with a hint of being dry fouled: black soot buildup according to this chart http://www.4x4review.com/Features/Te...6/Default.aspx
My thoughts are the ignition control, starter/ignition coil or wiring -- none of that has ever been removed/replaced/fiddled with? Could that be the case or am just chasing a ghost? How could I test those? Or could it just be flooded?
I DREAD taking this thing into the shop b/c the hassle it is and I'm more than comfy getting parts and tearing into it myself.
Thanks in advance.
Jonathan
Thanks in advance.
Jonathan
