coastalmainer
Just re-powered with this motor this summer...and have some starting issues. The ignition that was put in is a Yamaha ignition...so there are no green/ red lights at the ignition switch. When I turn the key on I hear the two beeps and the fuel injection is audible. When it cranks it takes a long 10-20 seconds...then a third beep occurs and it starts right up.
After starting it seems to be fine, I am just concerned with the long crank time. Also, if i put the throttle up too fast it hesitates (nearly stalls)...if I throttle up slowly it works fine...
Another question would be appropriate pro size...the 130 is 25" and is on a 78 mako 20...
Any advice before I haul it out would be welcomed...thanks
