Jeff Woodruff
I have a 2001 90 HP Johnson. Recently I have had trouble starting after it was warm. It acts like a cold start, ie: I have to pump the fuel inline bulb, and hold the choke in for about 10 seconds before it starts, and that isn't always a guaranteed start. Sometimes it takes several tries. My mechanic tells me that is the ethanol evaporating from motor heat after I turn it off, and that I will always have that problem.
In addition to that, 3 weeks ago, while running about at about 15 mph down the ICW, it just died, almost like it ran out of gas. It did restart, like described above, but now with a loud tapping noise, which sounds like it is coming from the top of the motor. This tapping noise sounds relative to the RPM of the motor, I speed up: louder, faster tap. Oil level is full, the tell-tale is working. Again, the same mechanic, says that is "piston slap" or the piston hitting the rings. Unless I want to spend a lot of $$, then I have to live with it.
Last weekend, I went out again. Ran about 1 mile, the hot light came on, I shut her down and drift fished for about 45 minutes. Started back up, ran another mile, same thing. This happened 2 more times, each time with the same conditions. Finally, it ran without any piston slap or just dying out and no hot light for over 10 miles. Then it started happening again.
I am really confused as to what to think or do. Suggestions?
This motor has less than 200 hours on it. I'd hate to have to ditch it for another, but...
Help?
Help?
