NauticalWheelers
2001 250hp FICHT runs good when I put in, after a 20 mile run out to beach at the inlet and sitting there for give or take 6 hours in the heat of the day it'll run fine for about 15 miles then will bog out with zero warning, engine light will come on, let it idle down for about 15 seconds and it will jump right out of the hole. It'll run fine again for 2-5 minutes then with zero warning bog out again. It'll do this all the way back to the launch. Changed out the water separator and the fuel filter. Gas tank is full to 3/4 full. water coming out the pee hole is luke water(bay water is 88 f). Exhaust is clear. Spark plugs are slightly sooted, look normal to me. It doesn't sound like there is any skipping, just looses power and won't take fuel until I back all the way out of the throttle.
