2001 115 hp Johnson o/b
sharkin95
I have a 2001 seaswirl 1851 WA with a 115 johnson 2 stroke I'm getting 5,000 rpms at full throttle but my mph is only 29 mph. I'm thinking slipping prop? or what else?
2001 seaswirl 1851 WA my engine wot is 5500 but I should be getting at least 32-35 mph I have read with a 135 hp engine it hits speeds of 40 mph. The weight of the boat is 2350 lbs The compression is 150 on all 4 cyl.engine. bottom is clean....max engine power is 150hp
25hp is a big difference in speed. Your engine has the small diameter gearcase so run the biggest diameter prop you can. Your speed is about right for the 115...
My 2001 Johnson engine #J115VXSIC v4 loop chrg. 60 deg. thanks for the reply running a 14 3/4 x 17 pitch ss prop ......any suggestions for a better prop?
