Hi Everyone,
New to the forum here, your suggestions/feedback will beappreciated.
I have a 2000 Mercury 50HP carb version. When I first boughtit the motor ran rough around 2k rpm and would bog itself to quitting once in awhile. When I could get it through to the power band it ran smooth. Seafoamseemed to clear that problem up but included it in case it is pertinent to thecurrent issue.
The motor starts and idles perfectly when cold. I can runthe boat to the fishing grounds but quite often once I go to start it back upit won’t idle well or for very long. Sometimes it won’t even start. I’ll crankit over, sounds like it will run, but immediately falls on its face. In order to get itgoing I have to be ready on the throttle to rev it up otherwise it won’t go. Neverhappens when it is cold and is at its worst when it is hot outside and has beenoff for more than 15-20 mins. It does seem like the bulb isn’t holding pressureduring this scenario, should this be my first move?
Thanks in advance,
Adam
Thanks in advance,
Adam
