Kevmarti75
Hey guys I need some help. I just bought a 2001 tri-toon with a 150 ficht ram injection (E150FPLSSM). The engine runs great but there is a loud knocking noise that I have found coming from the lower unit while the engine is in neutral So I drained the lower unit and discovered the following. The magnets on the drain plugs seem to just have normal fuzzy metal no chunks. Only approx 1/2 to maybe 3/4 of a quart of oil came out. The oil was pure black and smelled bad and a little burnt.
So with that said 1 how much oil should be in the lower unit. 2 since no chucks of metal were on the magnets do y'all feel the gears might be okay. 3 if it wasn't enough oil in it would it cause it to knock.
