A friend gave me his pontoon boat and I've been trying to get the motor to run properly for several weeks now. The boat had been in the water for approximately one year with the motor trimmed down with the foot in the water. After one year of not being run we put a new battery on the boat, turned the key, and the motor fired right up. It had a rough idle and wanted to stall when going into gear but we managed to get it going and I drove it to the boat ramp where my trailer was waiting.
I pressure washed the algae off of the pontoons and decided to see if adding fresh gas to the tank would help clear up the rough idle. There were approximately 5 gallons of gas in the tank that had been treated with stabilizer a year ago. I added 15 gallons of fresh non-ethanol fuel to the tank and drove the boat until the tank was almost empty. At the end of the trip it still had a rough idle but seemed to be running well at WOT. I did notice the RPMs would not exceed 5k. I repeated filling the tank and running it almost empty a few more times and the idle never cleaned up. My friend who gave me the boat said it sounded like it was running like he remembered at WOT. He also said it had always had a very smooth idle and it was definitely not idling like it had in the past.
Since then I've done the following to try to get it to idle well:
- replaced the plugs - they were dry fouled
- replaced the fuel filter
- cleaned out the water separator resivoir
- was puzzled by engine fuel components not matching service manual diagram - discovered it had new VST / fuel pump installed
- removed and cleaned out the VST - it had very minimal patchy residue of some kind in the bottom
- replaced the fuel injectors with rebuilt injectors
- tried to measure fuel pressure but could not find proper fitting. determined special gauge/fitting required.
- replaced the fuel pressure regulator
- replaced the ECT sensor
- replaced the IAT sensor
- cleaned and inspected the IAC valve
- tested the overheat sensor (because I originally thought it was the ECT sensor)
- removed and cleaned the MAP sensor (sprayed MAF sensor cleaner into the sensor)
- removed and tested the thermostat - it is within spec
- checked compression - didn't realize I needed to have throttle wide open - cold, with throttle closed, all cylinders were 115psi
- read in some forums that plugged exhaust could be a possible issue. Dropped the foot and inspected exhaust ports from the bottom. All clear.
After all of that the motor still has a rough idle and I'm running out of ideas. Any help is greatly appreciated!
Thanks,
Billy
Thanks,
Billy
