I have a 200 hp Mercury 2000 model year. It is only running on the 2 center cylinders. I have changed fuel line from tank to the motor and the primer ball. Changed spark plugs and no change. Took it to the shop said the power head gasket was bad they changed it and it ran fine. Took it out 2 days later still not running. Called the shop said fuel pump was bad. I changed that and rebuilt the lower pump. Still no change. I have spark on the top two and bottom two cylinders. When I pull the plugs they are wet like it’s getting fuel just fine. Any one ever had this issue or heard of it ?
