murraybiomed
After winter storage took 200 hp Honda out for a fishing trip. Started great. I started every month during off season. All services done in off season as well. Fuel was topped off and stabilized. This California so we have a moderate winter as well so no extreme temps and boat is garaged. On fishing trip I put engine into gear and noted a vibration/rumble from engine at idle. Out of gear no vibration. Ran up rpms in gear and loss of power w vibration. Couldn't generate more than 4200 rpms and vibrating badly. Got on plane using trim tabs and when on plane the engine still wouldn't get above 4400 rpms doing 20 mph (normally 5800 and 40 mph). Still noting vibration and engine very noisy. Took off plane and ran in gear at idle. Engine would vibrate be noisy for an interval and then quiet down and stop vibrating for an interval. It was like the engine was running through bad fuel or something. No specific time periods for the good operation or bad operation. But because the vibration/noise did go away for periods I was able to rule out lower unit/prop. I summarized that if prop or lower unit was cause of this noise and vibration it would stay the while in gear the entire time. Ran boat in trailer and to repair shop. I assumed it was fuel or spark. I drained fuel, changed filters, and filled with fresh mid grade. Told shop lead tech that this was done and gave description of issue. This is where it gets bad. Shop calls a week later and says #6 cylinder failed leak down test. States they believe a cylinder/ring/valve is the cause. Asked for permission to pull head and inspect. I agreed if this was their recommendation. A day later I stopped by to see the progress and valve cover was only thing off. They stated they looked into cylinder with a camera and thought cylinder is damaged. They said they were pulling head off later that day for visual. Another two days and no call back. I call and am told cylinder is good and they want to send head to machine shop to have valves inspected. I am confused why this needs to go to a separate shop but I agree. I go onsite four days later and head is still there. I look it over with them and they agree it looks fine. I then ask when they did leak down test what did they hear. They explained they heard leak and pressure was lost. I asked specifically where- crankcase, intake/exhaust valves. They said adjacent cylinders to #6. I asked what does a leak to the cylinders mean and they said it is normally a head gasket failure. I asked why then are you sending the head to a machine shop. They felt it was necessary to rule it out. I asked if they did a wet compression test and they said no. I asked why if that might help eliminate the valves/head from the equation. They didn't have an answer and just felt it was necessary to send the head out for inspection. I didn't press the issue as I am not a outboard engine mechanic and needed to give the shop my support/benefit of the doubt. However, I am concerned that a lot of energy, money, time is being spent on this issue. I don't know how a bad cylinder could cause the intermittent operation I experienced on the water. I thought I would run this by folks who have this experience and just put down what I am sure has happened and what is currently being done to resolve it. Any help will be really appreciated. I just want my engine back and to do some fishing. Thank you in advance!!! Adam
