200 HP over heats
JJP301
Engine overheated when I ran it off the hose. So installed an impeller kit.
pressure went to 15lbs then 0 no water to very little water out of pee hole
The engine overheated. I removed and checked the thermostats they open and close.
I ran the engine without the stats again the alarm wwent off and it didn't pee
I just pulled the impeller out and it is has black goo it spots on the casing even though
I never started the engine without water.
I believe the water is not circulating through the engine. I can see up the water tube
to where it bends to go to the engine.
Anyone have any ideas what it could be?
Are you taping up any additional water intakes? Sometimes the muffs don't cover them all (some are kind of hidden) and, if not taped properly, you will suck air and instantly ruin your water pump. That's why I ONLY do driveway checks in a trash can.
I think Chris is right. Today I pulled the hose on the thermostat and put water through the engine. No blockage as I assumed
So itmust be the rectangular muffs
Thanks for the info I will be a lot more careful hooking up the muffs
Again thanks
