I have a 2001 efi , lead SN 0T. The engine has had an ongoing issue for 3 years. It has been intermittent, usually when first started cold it would idle high and not come on plane. Then suddenly it would start running fine. Last fall the oil gear stripped and the motor blew. I had it rebuilt by my usual guy who also got the problem to replicste. He said number 1 and 2 cylenders had fire but no output. Sent the computer for testing and it tested fine. I have worked through most of the ignition system either testing or replacing the major components before when the problem was hit and miss. Since it came back from rebuild and computer testing it will not come on plane at all and won't go above 3000 rpm even in neutral. It was also idling weak. I replaced the fuel pump at the advice of the mechanic and still no solution I am not familiar with all of the sensorswamps ND components in a fuel injected system, sensors ect.... I am at the point of pure frustration. Does anyone have any ideas?
