1999 Mercury 40 hp 2 stroke Overheat
Scoggs4
‘99 mercury 40 hp 2 stroke overheat alarm sounds after 5 mins of running. Has yet to sound when in gear WOT. Typically sounds only in idle after warmed up. Telltale has water coming out. I have replaced impeller (including housing/gaskets), tested and confirmed thermostat opens. Removed thermostat and ran, alarm sounded same as usual. Water comes out from top cylinder brass plug and bottom plug when tested. Will shoot block with infrared temp gun soon to confirm temp. What am I missing?
On my 1991 60hp. Per service manual, the alarm will sound for overheating, low oil(sometimes the float will stick) or high voltage. After replacing the water , and thermostat, checked my float in the oil reservoir. I then checked my voltage and my motor it’s putting out over 17 volts trying to charge my battery. Hope this helps.
Can you put the screenshot on here?
Remove the t-stat and look into housing on block . The passages on left & right maybe restricted or t-stat defective.
