Working on a 1999 Magnum 200 EFI cranks but will not start has spark looking to see if anyone can provide what the fuel pressure should be for the injectors also how can I test to make sure the ECU is sending the signal to operate the injectors?
Thanks in advance T.
And you have the toggling safety switch, rather than the button that's pressed in? If it's the button type, check the purple wire on any gauge- if there's no 12V on it, bypass the safety switch.Yes if i add fuel in the butterflies it will fire, the fuel pressure is at 36 psi key on, the RPM gauge doesnt move suspect it is bad the lanyard is in the run position.
It's the RPM SIGNAL that means something although I would also find out where the tach gauge comes from- if it's the coil, disconnect the gauge and if it starts, the gauge is likely grounding the gray wire- that was a cheap & easy way to prevent cars being stolen in the 1960s and 1970s- wire the tach to the body of a car, through a switch as a kill switch.Yes its the toggle switch, ok thanks will investigate the RPM gauge i have one I can temp wire up to see if guage or something else. Thanks!!!!
This is not correct as ECU get its signals from the switchboxes..tach signal does not go thru ECULook further into the lack of tach signal- if the ECM doesn't see RPM, it won't fire the injectors.
