Curtisimo81
Ok so I thought I had the kinks worked out in my motor (99 225 Johnson). Have taken the boat out quite a bit lately and it ran great. Yesterday I was out putting around and it ran good. Got to a spot fished for a bit and then started the motor. Started right up but when I when to take off it died. Started right back up and couldn’t get on plane it kept dying as soon as I gave it throttle. I figured well I better start heading towards the ramp (idling..). After about 5-8 mins of idling I figured lets try it again, it would let me go higher on the rpms but felt like it was missing. Then all of the sudden took off like a bad out of h*ll and ran great. Went to another spot fished some more and then the same thing happened. I got home checked compression, I’m good. Spark on all cylinders but the plugs look odd to me. I never seen them look like they do. Can anyone tell me your thoughts on it? Also all 6 carbs have been rebuilt. But I know they may not be adjusted properly. Also on the ears its coughing like crazy. I thought i blew it up, but compression is all within 10% of each other. Thanks for any help.
