HI All.. Wanted to get some input on reviving this motor.
Situation:
1999 BF90a has been sitting for years... and years....
***Fuel in carb bowl looks like molasses when I pumped new gas through. *** NOT GOOD!
Relevant Stats on Motor:
Compression PSI: (top of motor down) -- 181-171-171-180
NGK Plugs cleaned and replaced
Fresh Oil and Oil filter
Lower Unit In good Shape (Oil Replaced)
Hot Battery
Motor behavior:
It will turn over and TRY and run on 1 or 2 cylinders for 15 or 20 seconds but dies.
What I think it needs:
All 4 carbs Rebuilt / Replaced
Both Fuel Pumps rebuilt replaced
Do you know where I can purchase a rebuild kit for the fuel pumps or replacements that are reliable and or reasonably priced?
Donovan marine has a rebuild kit for the carbs. (Is that acceptable to use that kit? looks pretty simple)
Situation:
Hot Battery
Motor behavior:
