I was coming back when my motor started grinding at hi revs. I got her back to the ramp and took her out of gear and she sounded fine when I revved her up in neutral. This morning, I checked the gear oil and it was milky. I last replaced it in the spring about 45 hours ago on the motor.
The motor is a 1999 Honda BF25 Long Shaft
I removed the lower unit and did a pressure test, saw some bubbles coming from shift rod water seal.
My Honda service manual is not clear on how to replace it. Does anyone have any experience replacing this seal? Do I need to remove lower rod? If so How?
Thanks in advance
Dave
Thanks in advance
Dave
