Hi,
Been working on my mates engine. He was out the other day and thought the motor went into limp mode and wasnt reving very high. Checked the check engine light for codes and nothing thrown up.
Started up and noticed tell-tale wasnt flowing well and engine was hot to touch. Checked tell-tale piping and was full of **** so cleaned out. Engine temp reduced.
On applying throttle the engine would not pick up revs and wouldnt not hit full throttle.
So turned off and ran some tests below.
Started by doing a compression test - 200psi all cyclinders.
Spark plugs - Black not the the dark brown/tan colour i expected.
Spark plug test - all firing.
Fuel pressure - Satisfactory.
Injectors Test - Okay.
Noticed that after running the engine that there were pieces of salt/corrision coming out the exhaust. See photo...
Could these pieces of salt/corrision but blocking up the exhaust outlet causing the motor to run poorly. After running the engine for a few minutes and knocking the leg a significant amount of this crud was expelled.
Plan is to check the thermostat tonight and then possibly run some SaltX through the cooling system a few times to break this crud up...
After running the engine and the crud becoming less he was able to hit WOT again.
Should we take the propeller off and clean up the exhaust pipe?
Or would you suggest dropping the gearbox etc to get to the exhaust pipe and check the outlet out?
Have you seen this before and do you think that we are heading in the right direction with this?
