Millie Grace
am new to this forum so hopefully all you experts can give me some advise and or direction. have just got this 1999 boat in the fall of last year so this engine is new to me. did some maintenance over the winter compression all 120 125 across all 4 cylinders. had a fuel leak so replace the manual choke lever solenoid and operates as it should now. overhauled the vro with a kit off of amazon found a diaphram rubber cracked. fuel system all good holds no leaks ball pumps up and holds pressure. noticed alot of blueish smoke when running with muffs in driveway but up to cottage for the season. engine has lots of power idle was a little poor when first in water but improved possibly old gas in tank. possible causes carbs need to be looked at.?? sucking air on the fuel inlet hose somewhere?? one way check valve at suction line to block not sealing??? gasket issues???? not sure why it smokes at idle only when you take it off plane and idle eventually the blue smoke returns. have been monitoring the oil consumption and seems normal?? have not pulled plugs to inspect hate working on the water. any advise would be very appreciated thanks bob
