HELLO, I AM BEING STUMPED BY THIS ENGINE IF ANYONE HAS ANY HELPFUL ADVICE IT WOULD BE MUCH APPRECIATED. I HAVE LYNC AND SYNCED THE CARBS, CONFIRMED IDLE TIMING AND WOT TIMING. IDLE IS 5 AND WOT IS 18. I HAVE REPLACED ALL 6 CARB KITS AND ADJUSTED FLOATS TO THE RIGHT HEIGHT. I REPLACED THE VRO FUEL PUMP WITH THE NON OILING PUMP AND I AM JUST MIXING MY FUEL, ALL FUEL LINES FROM TANK TO ENGINE IS NEW AND ALL LINES UNDER THE COWL ARE NEW INCLUDING WATER SEPERATOR. THE CDI BOX IS NEW AND THE STATOR IS NEW. WHEN I TRANSIT FROM IDLE TO WOT IT STUMBLES AND DIES IF I PRESS THE KEY A FEW TIMES IT WILL RUN SMOOTH AND TAKE OFF WELL SO IT SEEMS ITS STARVING FOR FUEL BUT I HAVE TOOK EVERY POSSIBLE ISSUE ICAN THINK OF THAT IT MAY BE AND REBUILT CARBS AND REPLACED FUEL PUMP AND FUEL LINES AND ISSUE WILL NOT GO AWAY. THE CAVITATION POCKETS ARE CLEANED AND CARBS ARE ADJUSTED CORRECTLY AS OF THE OEM MANUAL FOR THIS ENGINE ANY HELP WOULD BE AWESOME. THANKS. ENGINE MODEL IS E225STLECS.
