My engine has the plastic carb bowls, I have gone through 2 sets of them this season. A full carb rebuild in Mar, and now new bowls. When I rebuilt them I never over torqued them, I just close the gaps. The bowls are warping and leak fuel at high rpms. I can only assume its from ethanol. I only use valve tech marine fuel and I still add a little stabil marine to the tanks at fill ups. Someone told me I should be sanding the bowls flat instead of buying new ones. The bowls have a ridge to help with the sealing of the gasket, I think its to help keep the gasket in place while securing the the bowl to the bodies. sanding them would remove this ridge, has anyone done this and what success have you had /not had.....
