"im new to boats. i just bough
"im new to boats. i just bought a 1998 baja 272 performance. 454 mag carbeurated. it has been problems so far im ready to give up.
problems started with a pop every once and a while at any speed thru carb, and a sudden loss of pawer for a sec. then it began to stall at idle and not start up for a few min i could turn it over and it would try to start then immediately die. it has a thunderbolt v ignition. changed the plugs rotor, plug wires, dist cap. didnt make a difference. and timing is dead on.
brought it to roadrunner marine in newiberia, la two weeks later and $2200 it still doesnt run right.
the sea pump was changed, new fuel pump, filter and (supposedly a new ignition control module) later, the boat starts!!! however i put it in the water and give it gas, no matter what throttle setting i get it to it will rev up to then after a second or so die down a couple thousand rpms, then pick back up and die down. this will go on for ever.....
they charged me 400 for a ignition module, when i was having problems with it on the water i began looking around and found that the ignition module was a used one. the mechanic told me that a new one was 600 and would have taken three weeks to get. i think that is B.S.!! I think i got screwed 2200$ latter and the thing still doesnt run right.
mechanic said it seems as if something electrical was heating up and then cutting out. thats why he changed the module. ....
someone help me please... im mechanically inclined. tell me what to check and i will..... i cant afford another 2200 for it to not still work.. i want to sue this guy i think he took me for a ride...."
