So I have searched this site up and down for a fix to my problem so here we go.
my motor is a J200stlece
Much like many other post the motor runs as long as I pump the primer bulb. I can hear the carb bowls fill up and seems to run until they are empty. I have a clear inline filter. It stays full with no air in it.
things I have done.
Compression in Cylinders are all 100 and one 95.
Spark gap test performed and all good spark
new champion spark plugs
rebuilt fuel pump with purple diaphragm
cleaned and sanded warping out of carbs
So now it is warning no oil and check engine which it did not do initially when the problem started. Was thinking vaccum line out of crainkcase??? Do not know how to test it. It is the blue barbed fitting. I have taken the vaccum line off and turned motor over and felt pressure coming out which seemed weird since it’s a VACUUM line??????? I did check that line and it is clear of defects.
anything will help. Thank you ahead of time
things I have done.
