FTCS_Shane
I've combed through all the many power pack forum entries and can't really find anything that matches my problem. I have an ORIGINAL service manual on the way and may even receive it today.
I recently purchased this boat after it had reportedly been sitting in the previous owners yard for two years.
Using this forum, I've already fought through a failed emergency kill switch issue that caused no spark initially.
Here's my issue:
I have good spark on all cylinders except the middle cylinder on the starboard side.
Most of what I've read points to either power pack or stator. But, would a stator cause no spark in only one cylinder? or does it point to power pack? Same question though, does power pack fail at just one cylinder? I've ruled out the coil by moving the coil around to other cylinders and testing good. I've also ruled out "most" of the wire to the coil by doing a conductivity test from as high up on the wire as I can down to the connector.
Also, It appears to me I'll have to remove the flywheel for a powerpack replacement on this motor, is that indeed the case?
Thank guys.
Here's my issue:
Thank guys.
