I have a 1996 Merc 115 that runs and idles great but at WOT it will only run great for about 2-3 minutes then dies. It is almost like it seizes. The motor will turn over but the starter is working hard to make that happen. Won't start for about 10 minutes then it will fire back up, idle fine and run for another 2-3 minutes at WOT. Water pump and fuel pump are working and new. I checked the compression and cyl 1,2,4 @ 110 and 3 @ 60. Would a cylinder at 60 psi cause this?
Thanks in advance
Jeff
Thanks in advance
Jeff
