Robert4599
Hey guys i have a 1996 Mariner Magnum 40 hp that wont fire. I have had trouble with this engine idling for a while and i took the carburetors apart to clean them and then the motor wouldn’t start again. I deleted the oil injection system and premixed but it didnt help. I have the service manual and i ensured the carbs were up to specification, i also tested all the electrical parts on the motor and i had to replace the coils and spark plug wires and spark plugs. I have also recently replaced the starter and the starter relay. The only thing that doesn’t pass the test is the rectifier, but that shouldn’t affect the motor starting right? Battery has 13 volts! And the cylinders are getting fuel, the engine has 120psi on all cylinders but it wont even hit. I can ground the spark plugs out and see a blue spark but when i use a spark gap tester it doesn’t show a spark crossing the 1/4 inch gap. What is going wrong???
Thank you in advance!
-Robert4599
-Robert4599
