95 Evinrude 225, hard finding neutral from forward or reverse. Whichever gear I'm coming out of i have to go past the neutral position just slightly and then it finds neutral.
I adjusted the cable per manual but it did not help.
I've had this motor for years and this problem just started, the LU has not been off.
Pushed down (fully depressed) on the switch interrupt and it cut the starboard cylinder like it is supposed too.
Can the shift rod height adjustment change by itself ?
I was thinking maybe the interrupt switch is not working properly ( plunger has to go down farther for full contact?)
