Re: BF25 not starting
Describe what you are doing to try and start the motor. Did you try a squirt of gas into the carb? DON"T USE ETHER! That stuff is an engine killer. The spark on these is very faint and hard to see. How are you testing for spark?
I have found the Honda ignition systems to be very reliable. I realize not everyone is so equipped, but on no starts after a winter lay up, I go right to the propane. I release propane into the carb intake and see if she will cough, sputter or run. Pretty much every time they do and I go right to taking down the carb and cleaning it.
I've only replaced one ignition coil on a Honda twin in 6 years and even that engine would run, albeit badly. But, I have repaired/rebuilt/cleaned a couple of hundred Honda carburetors in that time. It's the weak link on a Honda. Especially if it isn't properly drained and stored.
A timing light and a 12 volt battery is a pretty reliable way to check that there is ignition. Again, not something you just pull out of your pocket but if you're going to be the mechanic, you havta tool up.
