bayliner20
To all:
As a new boat owner (or more accurately, a new owner of an old boat!), I would be interested in advice or opinions from anyone on my situation.
I have a 1988 Bayliner 20 foot Capri cuddy cabin (model 2152) with a 1994 OMC 5L 230HP I/O engine. *I recently had it out on the water, brought the boat up to 20 knots, but after about 5-10 minutes it died and thereafter would not go faster than 6 knots. *I brought it into a boatyard, which did a compression test of the engine, with the following results:
Cyl 1: *20 PSI
Cyl 2: *20 PSI
Cyl 3: 150 PSI
Cyl 4: 150 PSI
Cyl 5: 130 PSI
Cyl 6: 120 PSI
Cyl 7: 130 PSI
Cyl 8: 150 PSI
The first two cylinders are definitely shot, but I assume the entire engine is shot as well and not worth a repair. *Do others agree? *The boatyard will put in a remanufactured engine for about $5,000, but I'm not sure the boat is worth it. *The seats in the stern and the engine housing, both made of plywood, has dry rot. *The boat has seen better days.
What do others think?
Thanks.
--bayliner20
Cyl 1: *20 PSI
Cyl 2: *20 PSI
Cyl 3: 150 PSI
Cyl 4: 150 PSI
Cyl 5: 130 PSI
Cyl 6: 120 PSI
Cyl 7: 130 PSI
Cyl 8: 150 PSI
Thanks.
--bayliner20
