I have a 1995 Evinrude 175hp that I purchased used in 2006. Shortly after purchase, the rectifier burnt up, and I replaced it with a CDI. Took the boat out for a run this past weekend and everything was running great. About an hour into the ride, I noticed the tach stopped working. Loaded up and come home to trouble shoot the problem. I still have charging at the batter, 13+ volts at idle. Stator ohms out per manual, .12 ohms and no ground. Not getting any voltage from gray wire running or not. So, figure I need a new rectifier. But I tried Joe's troubleshooting guide and connected the gray wire to the tach to the yellow/gray wire from stator and still don't have any tach. May have a bad tach also? I was wondering if the VRO stops working if it's not getting any signal from the gray wire?
