1995 150 hp Evinrude:
MFBJ
My motor will start good and idle down smoothly. After boat is on plain the motor dies as if the key is turn off. This will happen at low speed as well. Has enyone had the same issue? After it sets for a short time will start again and run good till it dies. Thank you for any advice on a solution.
Thank you! I'm reading though it now, my problem may be that my stator is shorting out when it gets hot. Still trying to educate my self. Thanks again Boobie.
