Good evening/morning,
My name is James
Im new to the forum, and would like to ask your advise please.
I am sure this has been covered somewhere, I just couldn't find it.
I recently purchased a 1994 searay select. It have a 7.4 bravo
in it.
it had been in storage for 7 years, boat is immaculate, when I picked it up I sent it streight to the marine mechanic, had the pull the leg and do a service, bellows, shift cables, seals ect.
I then picked it up and put the following on,
new impellor
new water pump
new thermostat
new fuel filter
oil
oil filter
pulled Risers and checked they were new.
After all all this I started it.
engine ran well, running on all cylinders not missing or carrying on. However 10 min in it started getting warm, we **** it off and went on to flushing block and all hoses. Engine never went over 180-190
put it all back together and started it up, it ran bad missing and carrying on. And over heating.
pilled riser off and there was water in exhausts, piles plugs and filled with wd40. Put new manifolds on new riser gaskets and put rusers back. Found bits of impellor in power steering cooler.
started boat and it ran beautiful, didn't over heat and ran perfectly smooth.
desided I would take it to the ramp and go for a run, after a 15min commute to the ramp I backed boat in and started. It
ran horrible again, missing and carrying on.
took plugs out and I had water again!
could anyone suggest what to do next? Could it be inlet manifold? I'm lost.
sorry for long post just wanted to give as much info as possible.
thanks again,
James
My name is James
in it.
new impellor
new water pump
new thermostat
new fuel filter
oil
oil filter
thanks again,
James
