This engine will idle and run fine with cuffs in yard but in the water it will stall out at idle
I can go fast and it will run fine all day at speed, but when you go back to idle it runs
for a short time ( ten seconds ) and then stall out. I can restart and get it going quickly
and it will run at speed again, but loading the trailer is really tough
I have good compression readings all cylinders
I have had overhauled six carbs completely
Replaced the power pack with ignition wires and plugs
Replaced the optical sensor
complete new tank of gas
and several more parts.....
I have tried putting seafoam in the gas tank and spraying it heavy into the air jets ( 12 )
but nothing I have done has corrected this problem
Could use some ideas????
Larry
Larry
