Charles K.
I have a rattle noise at the rear starboard side near the turbo of my 8v92. It sounds like a rocker arm rattling loose on top the head, but I am not having any issues with it running and the noise does not get worse with increased rpm. I'm an old Chevy small block guy and I've never torn down a Detroit, so I'm assuming it has rocker arms on top the heads and intake/exhaust valves too; I know it's a two stroke engine, so maybe the cylinders are ported instead and a loose rocker arm isn't possible? I have checked the turbo and it rotates freely without any play in the shaft and seems to be the same as the other turbo's; I checked them all thinking it was a bad shaft bearing on the turbo. I've tried placing a metal rod to spots all around the area and my ear, but I am not hearing anything to pinpoint the noise. The noise is not real loud and could have been there a while, but I recently noticed the noise while checking the raw water intake strainers after I cleaned them, something I do everytime I crank up afterwards. When I heard the noise I moved to the port engine and could not hear the same noise on it, but I could still hear the noise coming from the starboard engine, so I know it's not normal. I did take the boat out and ran it at normal cruising speed to check temp readings with my infrared thermometer all around the engine, but most all reading were a little cooler on the starboard engine as compared to the port engine, so that didn't point to anything either. As I said the noise doesn't get louder with higher rpm and the engine runs good as ever, so I'm lost as what this noise could be. Anyone out there have any clues?
