This weekend my motor began losing power around 3000 rpms. My troubleshooting so far.
I checked that fuel was in all 3 carb bowls, drained all 3 bowls(no water or junk) changed fuel filter.
I then removed one spark plug wire at a time and isolated that the missing cylinder was the top one.
Using an inductive timing light, it shows lost of spark at 3000 rpms on the top cylinder. I installed a new spark plug and no change in lost of spark. I then switched coils and again no change the top cylinder still loses spark at 3000 rpms.
I actually had a spare switch box, and changed switch boxes, with again no change in lost of spark in the top cylinder, what else should I consider. I have ordered a new spark plug wire, just in case it is shorting out at high rpm, but asking now for any other ideas as to what could be causing my ignition problem.
Thanks in advance,
Gary
Thanks in advance,
Gary
