Ramjamjungle
I have a 1994 Johnson 150 HP Model J150EXERV---Having trouble with starting and carb flooding. I have a few questions I hope someone can answer. I rebuilt the six carbs with new gaskets and float needle/seats. etc. Bowls were warped so sanded them flat and adjusted floats etc. seems to me the needles should be able to stop the flow of fuel when the bulb is pumped however carbs are dripping fuel out the intake on most all of them if I pump the bulb. Can the bulb overpower the float needles or is fuel getting past the thin squiggly gasket that is embedded in the carb body backside and flowing into the carb throat?
My other question is---All the carbs have a vacuum port tube mounted on the body backside. These are all uncapped and open to the air. Doesn't this cause a vacuum leak into the intake? How does this not mess up the mixture?
