In post #1, you say... "gas leaks from the inside of carburetor but only when motor is running."
In post #15, you say... "it does spit gas out the front of carb only running at idle speed. When you open it up it is not as noticeable."
In reading post #1, it came across to me that fuel was really flowing out the carburetor throat
In reading post #15, that scenario is a common one that indicates a lean running cylinder due to a warped gasket sealing area (carburetor to throttle body... throttle body to intake manifold), a improperly seated goofy O Ring seal between the carburetor and the intake manifold if so equipped... OR... someone installing the intermediate and slow speed air bleed orifices backwards.
Some "mechanics" are still hung up, mistakenly thinking that those orifices measure fuel when they're actually measuring air, leading them to install orifices with a larger inside diameter that actually make the lean setting worse.
The jets are imprinted on their sides as to what size they are (inside diameter). My books only go up to 1992 (I retired) and the 1992 175hp uses Intermediate Air Bleed Jet 317473, size #30 (.030)... and ... Idle Air Bleed Jet 327745, size #40 (.040).
The Slow Speed Air Bleed Jet is always the bottom of the two jets.
If you ever suspect one of these type carburetors to be running lean.... with it running and spitting back, simply stick your finger over the opening of that slow speed air bleed jet. That'll make the carburetor run richer... sort of having you act as a manual choke. If, when you do that, the engine sort of smooths out somewhat... you've found the offending carburetor.
Check with your dealership as to what size those air bleed jets on that 1993 175hp model should be.
