Frank OBerry
I have been reading every post i can about testing rectifier regulator and stator. I tested the rectifier with ohm meter set on diode test it has two yellow leads from stator both tested ok the gray lead for the tach im not sure what it should read. It also has a purple lead i saw nothing about it except maybe it get keyed power when key on. The staor two yellow leads had 0.5 ohms and continuity. Visual check of what i can see of stator doesn't show over heating. Brand new batteries dual setup with isolator switch. The only thing i didn't check was the purple wire while the rectifier was still hooked up to see if it was getting power if that's what it's supposed to get. Anyone have any ideas? I'm disables and don't really have the money to take it in to a shop or to start throwing parts at it.
