1993 Evenrude
" I would like to add a chargi
" I would like to add a charging system to my trolling motor but I can't seem to find an altenator kit now that OMC has changed hands, does anyone know if I could use one off an older motor? The motor is a 9.9hp Evenrude. "
"TrollingBob.... There are two
"TrollingBob.... There are two different charging systems for the 9.9/15hp as well as other hps.
Yours would take OMC part #174037 which lists for approx $68.00. It is designed to fit from 1983 to 1988, and of course also 1993.
However, OMC PART # 175251 which lists for approx $62.00, which also fits the 9.9/15hp WILL NOT FIT your engine. This kit is designed to fit the 1989 through 1992 engines.
Bottom line: Use part #174037 only! If you find one from a used 9.9hp of 15hp, make sure that the letters of CT, CR, CO, CD, CU, CC, or ET are in the "Model Number".
OMC's code is the word INTRODUCES where each letter stands for a number.... CT=83, CR=84 etc etc.
Joe
" Joe, I can't thank you e
" Joe, I can't thank you enough for the part number, my local guy said if he could get an altenator kit it would be $182.00 his cost. Armed with the # you gave me I found one on line at MasterTech Marine for $62.50 shiping included. Once again THANK'S and keep up the good work, thi is a great site. Bob Allen aka. Trollingbob "
