1993 4.3 valve adjustment
Markhodges78
I will be replacing a head on a 1993 OMC Cobra 4.3 Model number 432APRJVN The manual that I have states to torque head in 3 steps to 25, 45, 65, and torque valves to 40 ft. Ibs. on 1992-96 V6 engines. so this means no lash adjustment for this engine? does this sound right?
ok...FWIW, the 4.3 engines went thru a lot of changes in the early 90's, so referencing a "model year" doesn't always yield the best answers.
Who published the manual you cited?
Is the engine the original one?
I do not know Who published it it doesn't say any where that i can find I only was given the few pages relating to the head replacment
Yes original engine
I'd go with the cylinder head torque as AllDodge suggested.
The rockers will need adjusting (vs a flat torque value)...you can do it when you assemble it or while its running. Unfortunately, what you posted from the manual pages doesn't give you all of the info to do it during assembly...
I'd be inclined to see if you can get the engine ID data off the block - there should be a 'milled ledge' on top of the LH water pump mounting boss when looking at the front of the engine. casting numbers also help determing what you have...
P/N 3853649looks like a torque nut and not self locking
If this is what is on the rockers then you should be good with just torque and forget
As a backup and method to double check, before you loosen/remove any rocker nut
Rotate crank until one of the valves on a cylinder is partly or fully opened.
Now loosen the other rocker until push rod is loose.
Tighten nut feeling for zero lash. When zero lash is met, tighten nut.
If you get much more than 1 full turn let us know because something isn't adding up
VP is known for not making a good manual and not keeping obsolete parts updated
I'll look and report back
Ok thanks ... If it has roller lifters then its torque and leave?
Another piece of info is that ii has an electric fuel pump and the block is not drilled for a mechanical. Also the head casting is 064 I know this because I took the valve cover off to check before ordering the head but I did not think to check the rockers
Ok it gets worse.. pulled the intake off and found that the block was cracked..
Can I replace the engine with an 88 omc 4.3 ?
