Cactus Rat
During my annual clean and tune I noticed that there was a fuel leak between the fuel bowl and the lid of the vapor separator. The screws must have vibrated loose after 23 years of use, anyway there was a substantial fuel leak. Pumping the fuel line bulb caused fuel to spray out of the seam and the bulb would not hold pressure. I tightened the screws and it still leaked so I ordered and replaced the gasket between the bowl and lid. Leak stopped and now the fuel line bulb holds pressure. Engine fires and idles just as always. The problem is that once you move the throttle off idle the engine dies. It dies if the gear case is engaged or disengaged. Also it will only idle for two minutes at the most and then die. It will start right up again but only idle for a minute or two. I am sure it is a fuel problem and has to do with me replacing the gasket but what did I do wrong and how do I correct the problem? I did not remove the pump and mounting plate from the engine and I only disconnected two lines from the cover to have enough room to remove the old gasket and slip in the new gasket. I have triple checked all the hoses and wires and all are still connected. What do I do to correct this problem???
