mashed_finger
I'm in trouble and can't for the life of me figure this out. Here's the skinny; Up to this morning the boat ran perfectly, it had what I would call a "wink out" electrical problem, where it would run, then nothing, no gauges no starter no trim pump nothing. This boat does not have fuses, it has breakers, and none of them would flip. So, since I have had ign. switch problems, I replaced that, it has a brand new solenoid, new ESC, new distributer, coil, ballast resistor etc. So this morning the wife and I got up to load up the boat to go to the lake, I get in to start it, just to make sure it is ok, and the starter would run, but the engine would not turn over. All the wiring to the coil is new, as to the distributer. I had put the out drive down to start the thing, and after I cranked , I stopped to see if there was gas in the carb....., there was. When I sat back down to turn the key, nothing happened, except I heard a snapping sound come from the engine. I checked the breakers and nothing had flipped, so I changed out batteries to one I knew was in excellent condition, same thing. None of my gauges work like they are supposed to, when I turn on the blower and the bilge or the nav lights, the gauges all flip to their highest readings. So I started jumping things, and I bought and installed a new solenoid...., nothing. So I decided I would take a screw driver and jump across ign terminals, and it made no difference at all. I went and jumped across the new solenoid and nothing happened, so I went back and jumped across the ign terminals again, and heard the new solenoid snapping. I got back in the drivers seat and turned on the key and all the gauges worked normal, and the outdrive pump worked once again as normal. So I thought I would try and start the engine, and as soon as I turned over the key, I heard a snap coming from the engine compartment, and everything went back to malfunctioning again. I got out the selock book, but frankly I am stumped. Has anyone had this happen to them, and if so, what did you do to fix it. Is it possible that my starter has gone T.U on me, if so, why would I lose ign. spark, when I had it all perfectly the last time the boat ran, I have not touched a thing until this morning. So any advise would be most helpful, if I can't fix this, I am going to have to take it in at over 90bucks per hour......Help! Rick
