Howdy all,
My 1992 Mercury 200 (2.5L) carb won't rev over 3,000 RPM under load!
After about 30 minutes of 4,500 operation (on plane, engine running great, boat at 32 MPH or so), engine power shut down like a light switch (so I'm thinking electrical).
-Starts right up and idles like normal.
-Revs to 3,000 with a slight shake.
-Hits a wall at 3,000 under load.
-Compression 130 on all cylinders.
Forums say likely bad high speed windings on stator, so I replaced that with a new one even though the original tested OK.
I have a parts engine with newer electronics an some new parts laying around, so far swapped over:
-Power packs.
-Trigger (my wire insulation was mushy, pulling away).
-New plugs and wires.
Checked spark with timing light, all cylinders are firing at idle.
Is there some sort of "limp mode" switch on the engine to keep RPM low?
EDIT:
This guy had the same problem, one day it suddenly ran fine! Sounds like a loose connection.
https://www.screamandfly.com/showthread.php?254186-Motor-not-running-above-2000-rpms
Thanks,
John Hub
-Power packs.
EDIT:
Thanks,
John Hub
