SnapperBlues
Hello,
I have a 1990 Johnson 200 looper (J200TXESM) that I am trying to resurrect. I purchased the outboard from a gentelman that had it sitting for 5 years for 200 dollars.
He said it ran good the last time he used it and that he had just replaced the flywheel and starter.
I removed the VRO prior to testing anything. I had a new vro pump with the oil delete handy.
Initially I was not getting any spark, with a good 850MCA battery. I diagnosed that the stator was bad with my fluke and a DVA adapter.
I tested the resistance of the timerbase per the CDI troubleshooting and outboardignition.com instructions and it tested fine.
After replacing the stator, I found that the power pack was sending uneven voltage to each coil. So I replaced that.
With new champion ql77jc4 plugs, the engine will idle (in a test tank), but erratically. It shakes a bit. If I give it throttle, it tries, but then falls flat on its face. Pumping the primer bulb and pushing the choke have no effect on the result.
I have cleaned the carbs, and throttle body holes. 4 of my 6 plastic carburetors leak around the bowl where they meet the carburetor. I plan to buy new bowls, but I'm not certain that this is the issue.
From my research, these are low compression engines, my measurements are as follows:
76,76,82,80,85,85
These are after idling for a few minutes or so on ethanol free gas and xd50 oil 50:1.
I have a clymer manual which is what it is.
I'm trying to determine if this may be a fuel issue or an ignition/timing issue at this point.
76,76,82,80,85,85
