My 1990 Johnson 200hp (J200TXESM) carburetor high speed/main jets are stamp 62D 0.062" but the hole measures 0.075" It looks like somebody may have drilled them out. Is it common to do this? I'm in Texas if altitude madders. this motor seems to use a lot of fuel. I don't have an exact measurement, but it went through 12 gal pretty quick. The plugs seem to be dark and a little on the damp side. It seems to idle but the acceleration is rough and it sounds like a cylinder is cutting in and out and then clears up. The idle and intermediate air jets are 42 and 36.
I have had other fuel related problem that I've been working on, but since then this is what has been done: external tank with direct connected to hose (no air leak) new 3/8 fuel hose direct connected to duel fuel pump with new OMC kits (pump fuel pressure= 7 psig. at idle (bench tested pump and it held vacuum and pressure with no leak down on check valves and impulse port) The fuel pump was a cheap brand pump. It had a leaking diaphragm I fixed that and tried the motor out and on the top in it would start running out of gas, had to keep squeezing the gas bulb to keep it running. I hope that all of what I've done fixes the problem. Just wandering if the jets being so big, that the fuel pump could not keep up. will find out tomorrow.
Just a FYI I have found out the hard way and want to let others know of things I've found that could be problems for others. I bought one of the light gray fuel hose from Academy and cut the end off so I could connect it directly to the fuel pump. luckily I had pin hole leak at the clamp. When I pulled the hose off to recut it, I noticed it looked like a peace of clear plastic wadded up inside the hose, plugging up the fuel pump port. it turn out to be the hose liner. I did not know these hoses have plastic liners in them that will wad up if you try to modify them. Another lesson learned is cheap fuel pump vs. OMC there is a big difference in the quality in the rubber check valves. After replacing them with OMC there was absolutely no leak down from pressure and vacuum test, the cheap ones would not hold at all.
