Shift and throttle cables mixed up ?----How did it work for you last season ?----What work was done on the lower unit ?----Water pump impeller change ?------
They often jump into forward when you are not looking.---Spring loaded clutch dog.-----So drop the lower unit again.----Turn ( with visegrip) shift rod CCW till you find neutral.---Reassemble.
