1989 Johnson 200 hp trim and tilt question
Cessna340
The trim and tilt on this motor makes a groaning sound thru the up and down trim area. All other up and down operations are good and they are silent. I have checked fluid level, all joints that move do move and have been greased. I would appreciate any help with this problem. Thanks
What happens on salt water motors is this.-------Corrosion products ( white powder ) form between the plastic bushings and the brackets of the tilt tube.-----This usually causes binding and the snap crackel / popping.
Well located problem with trim and tilt. Found o rings all wadded up in starboard trim ram. Replaced o rings and no more noise. Works great. Hope this info is helpful to someone else.
