I have a 1989 50hp Merc 3 cylinder 2 stroke and it has no upper end of throttle power. I have eliminated fuel as a problem after replacing or rebuilding every fuel component from tank the carbs.
It gets to about 1500-2000 rpm and goes no higher. It doesn't stumble or die just will run at lower rpm.
I was troubleshooting the ign system and started with a visual inspection of components. Flywheel looked good and was installed correctly. Stator was clean, crack or break free, when I looked it the trigger I noticed what appeared to be a built in in-line fuse holder that was empty on the top of the trigger
I checked the wiring diagrams and parts lists and couldn't find anything. Does anyone know if this is a fuse or nothing?
If I can eliminate this I will move to visually checking the rest of the ignition system and them testing individual components. I like to do these type of things in a systematic way and would like to rule out things as I see them before moving to the next component down the line.
Thank you
Thank you
