There is no key, just a kill switch and intermittent toggle switch to turn on the starting solenoid to send power to the starter. But let’s forget about the electric start components and pretend that it’s only pull start.
As for spacing of the power pack (the new blue component), I mounted it loosely on the plate, put a business card against the outside edge, then gently placed the flywheel on. Removed the flywheel, tightened the screws (with blue locktite). However, there really wasn’t much slack in the positioning of the powerpack screw holes.
Where are you seeing the melted area, Tim?
Simplified readings:
Rectifer
black lead to red wire, red lead to each yellow: yes
Red lead to ground, black lead to yellows: yes, higher than above
Red lead to ground, black lead to yellows: yes for both
Reversed the leads on the wires and got no readings.
Stator
Black lead to yellow, red lead to y/grey: yes
Black lead to yellow, red lead to y/blue: yes
Black lead to solid yellow, red lead to ground: no
charging coil wires are under the plate.
I will get back with you on the power pack and ignition coils readings when I get home or to the guys house.
Hopefully this cleared some things up
Rectifer
Stator
