I had many little issues I've tried to nip, now there's another. I'll start with what I've done.
Had a spark not firing, so replaced coil, now works. Had leaking fuel lines, replaced them all. Cleaned carbs and put new kit on them as well as a link and sink. Replaced regulator, rectifier. Impeller kit installed. Timing checked. Fuel filter replaced.
Problem that I have is the boat is a little slow out of hole, and wot is 4400 rpms at 50 GPS mph. I have a 24p prop, and tried a 19p prop but only gained 600 rpms. This motor should sling a 24p prop, with good compression.
So, I looked on the net and noticed this motor (j150stlcca) should have a 1 3/8 carb, but the one I have has the 1 5/16 carb ????? Could that be the issue? The reason I am - 1000 rpms?
